on the Sr3300T spektrum rx...a question
I am already using the 3 channels...last one is for an external bec...so this leaves me short on the fan plug for my mm. Can I power the fan on top of the mm through any other slot on the rx?
Or am I SOL. Too much of a chicken to find out..would rather ask than ruin a $ 100- rx |
NO!!! The sensor ports are 3.3v IIRC use a Y splitter - the traxxas ones are cheap
Yup I was right....
From the manual Power the receiver through any port that is not a 3.3V Telemetry port. The amber LED will flash continuously, indicating the receiver is in bind mode. WARNING: Do not power the SR3300T through the LAP, TEMP, or RPM Port the receiver will be damaged So it goes I wouldn't draw power either and you'd only get 3.3v |
This is why I double check first! |
Doesn't really matter - The + and - on all the other channels are linked...
| All times are GMT -4. The time now is 08:48 AM. |
