-   -   pinion ? (https://www.rc-monster.com/forum/showthread.php?t=25718)
anthony213 02.07.2010 07:11 PM
pinion ?
does mike have mod 1 pinions with the 10th scale size motor shaft ? or do i use the bore reducer ? and witch size ? got one of the new jammin scrt 's , 1/8th scale center diff but a 10th scale motor .
PBO 02.07.2010 07:59 PM
You'd need to use the 1/8 bore reducer to fit the 1/8 shaft
lincpimp 02.07.2010 09:53 PM
Yes, not many 1/8 bore mod 1 pinions out there, and none that I know of that are hardened for use with a steel spur. Get the bore reducer and rcm pinions, best way to go. Until you break the 1/8 shaft on the motor, then you can get a good motor with a 5mm shaft and use the pinions w/o the bore reducer.
