truggy corr conversion?
can 1/8 truggies be converted to corr truck? am thinking about putting a corr body on my mbx5t.is it possible?
Maybe, if you put buggy arms and driveshafts you can fit an SC8 body on. I am thinking about doing the same, but with my XB8 and XT8 parts I have lying around.
Already have a buggy with an SC10 body on it with SC8 bumpers, and it is much better driving than a Slash or SC10 (for my style of bashing anyway). |
^+1. Most buggies fit Slash/SC8 bodies pretty well, so a truggy would likely be a bit too long/wide to fit right without modifications.
I have an 8ight-t that I swapped buggy arms, shafts onto. Fits the sc8 body perfect. It is probably cheaper starting with a buggy, then just using the truggy chassis plate if you want to go with the sc8 lenght. As stated the slash body length will drop on a 1/8 buggy just right.
Here's a shot of my RC8T with a modified SC8 body.
http://lh4.ggpht.com/_dcy74CG15Qk/S2...0/IMG_4720.JPG Quote:
I have more photos of it. However, yes I had to cut out the wheel arches probably a good 3/8"s of an inch. Also created some body mounts using aluminum sheet and the SC8 body mounts as the body needed to be raised even with the wheel arches cutout. Its running on Pro-Line Badlands MT with Maximizer beadlocks.
But yeah, I sorta liked the look myself, however I did not want to lose the width of the truggy. Quote:
sc8 body
I've also taped the insides of the tires to "help" with the ballooning issue.
Yup, I used the same thing myself and found out I had no ballooning either.
I was really disappointed with the SC8, its basically a buggy with the longer chassis. And its really not that much bigger than the crop of 4x4 SC trucks. :| Now if they would come out with an SC body for 1/8 truggies, that would be killer. Quote:
Yup. Just flip the tires inside out, run a circle of tape around the circumference of the tire without overlapping the tape. Then flip the tires back and install as normal.
| All times are GMT -4. The time now is 06:07 PM. |
