-   -   Amp. per phase!? (https://www.rc-monster.com/forum/showthread.php?t=25819)
alport 02.14.2010 04:19 PM
Amp. per phase!?
My esc is rated 104amp max per phase.What is the meaning of "per phase". Is it continuous, peak current or something else?
BrianG 02.14.2010 04:24 PM
That means each of the three phases is rated for 104A. Some ESC makers would incorrectly take that value and multiple ny 3 to get 312A for the ESC rating. But it's anyone's guess if that's cont, burst, or whatever.
alport 02.14.2010 04:44 PM
It's a tekin r1 if it helps.
suicideneil 02.15.2010 07:31 PM
I'd take that to be 104amps total continuous rating at room temp (25*C). When things warm up, that rating drops- 'de-rating curve' I believe its called, so a hot esc will be less tolerant to bursts in current vs a nice cool one...
BrianG 02.15.2010 07:35 PM
And if that is true, then you can consider that 104A per phase value more like ~50A per phase because FET junction temps are usually quite a bit higher than FET case temps, and FET case temps are higher than heatsink temps. Unless of course, you run your ESC submerged in liquid nitrogen. :smile:
And Neil, you are right, it's called temperature derating.
