Neu motor heat up fast?
I have a neu 1515/3d was ok from the last race. Today tested the motor it did not even leave the pit n it was 158 fahren.
I check the drag brakes n binding it zero n ok. Diff is ok. So what's wrong? Motor? |
Anyone?
Sounds like the motor is de-magnetized.
I am thinking izzit the esc or the motor. |
was it with no load on the motor? they can heat up quick running without a load.
Shorted......I have gone through this already. Feels like it has a drag brake on right??? That is the symptom.... |
yup it shorted check your leads right at the can of the motor.
If it's shorted what can I do?
By "never left the pit" do you mean you were running it on a stand? That counts as a "no load" situation, or at least "not enough load". It's the same scenario as motor heat from too much tire spin. Take it out to the track and if it's still getting too hot then I guess contact Neu about warranty service.
there is nothing you can do with a shorted motor. either one of the leads has rubbed through on the can or broke internally... if neu dont warranty it you can pull the rotor and save it incase you come across a good can, or you can use it for a nice fridge magnet.
Can I open the motor myself? Will it be costly to repair it? I change to tekin n test it ok. So it's my neu that has problems.
What's the email address of neu? I tried to email them but no reply. |
Start saving for a new (neu) motor.
What??? That's bad if neu is designed this way? The wires will come lose one day. Then I rather get a CC neu or tekin no wire problems n cheaper!
| All times are GMT -4. The time now is 05:29 AM. |
