whats this noise? --video--
hey guys i figured before i pry open the tranny id throw up a quick vid to see if you all knew this noise
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid86.photobucket.com/albums/k93/t-maxxracer32/SDC10431.flv"> the pinion and spur look good.. pinion is a little sharp but other than that their mesh is ok and stuff. tires spin at the same time and stop at the same time so i dont think theres something binding them.. my next guess is the tranny.. this is an old rusty so i wouldnt be suprised but ya i just wanted to ask before i ripped it open thanks for any help. |
tiny rock stuck in a spur tooth? is the spur smooth throughout an entire rotation, or is there a rough spot?
its smooth throughout..
pinion and spur |
Time to pop it open... Sounds like the idler is worn down. :neutral:
dang was afraid of that.
well ill do it when i get some time thanks guys |
At the start of the video it almost sounds like there's a tooth broken off inside the diff... You might want to just take it all apart and check everything.
ya that is what I will do. I only put this truck together to see how it ran, but i might as well get it up and running clean
| All times are GMT -4. The time now is 05:27 AM. |
