need some help tuning a new engine
hey all,
I've just got my new OS 28xz. just finished running it in and i was being patient with it too. dont wanna spoil my first expensive engine. anyway... after breaking in was completed i started tuning the engine. problem is, every time the tank is full, it seems to run rich. once it reach to about half a tank or lower it becomes quite lean. is this normal? i didn't notice this behavior when i was using the 454 losi RTR engine. car: Losi 8T 2.0 engine: OS MAX .28XZ pipe: OS T2060SC Plug: OS P7 medium fuel: Sidewinder 30% had to add another head shim to reduce the compression cause it was running really hot (0.2+0.1+0.1mm shims) any opinion??? thanks |
That is normal hence tune your engine with the tank half full. By doing this, the engine is a bit rich when the tank is full but not overly lean when it is almost empty.
| All times are GMT -4. The time now is 04:14 AM. |
