Softest Springs for T-Maxx Shock?
Some of you may have seen my other thread regarding my school project. I've decided to go with a multilinj solid axle suspension. I was going to use some T-Maxx shocks that were lying around bu I figure I should get softer springs.
Anyone know of a softer spring than the red ones that come with the truck. Are the white slash ones any softer? I was thinking those might be good? Also I figure using a front shock spring and filling the gap with preload spacers may also work? Any ideas? Thanks BP |
Depends how much ground clearance you need, you could probably use some Slash front shocks.
Losi springs. Golds, grays, and whites are all softer than those Traxxas reds.
| All times are GMT -4. The time now is 02:37 AM. |
