-   Slipperential discussion (https://www.rc-monster.com/forum/forumdisplay.php?f=45)
-   -   AAAGH! I wasn't expecting that Mike! (https://www.rc-monster.com/forum/showthread.php?t=25940)
pinkpanda3310 02.24.2010 08:59 AM
It arrived today! Yes it arrived only just today (not the slipper but the cd mount). I bought the cd mount asap and then went with standard snail mail. I know it's only a few more dollars for express international but I forgot :oops:
So I mock it up at work after picking it up from the post office and drool on it a bit then tonight I decide to mock up a motor and diff. Hell, why not, lets fit the slipperential!
AAAGH! It doesn't fit! I wasn't expecting that. Did I not read or miss something? I know the 50+ tooth spurs don't fit with out a little dremelling but I honestly thought Mike's slipper will fit Mike's cd mount.
You can see the bearing stops short of the housing
http://www.rc-monster.com/forum/pict...&pictureid=523
http://www.rc-monster.com/forum/pict...&pictureid=524
http://www.rc-monster.com/forum/pict...&pictureid=525
jokerjustin 02.24.2010 09:17 AM
that is very strange..
Arct1k 02.24.2010 11:36 AM
Hardly strange. The slipperential is small so it can fit the majority of setups with shimming. The cd mount is large to fit with standard diffs.
Mike clearly states that the mount requires some mods fir mist setups and us nit for novices. Just drill another hole in top plate or add shims to both bearings.
Bondonutz 02.24.2010 11:45 AM
Drill another hole in top plate to move upright back for the bearing to get in the hole.
BrianG 02.24.2010 11:50 AM
Judging by the distance the bearing has to go, looks like he will have to drill a new top plate hole AND do some shimming on both sides.
RC-Monster Mike 02.24.2010 11:51 AM
Mike clearly states that the mount requires some mods for most setups and is not for novices. Just drill another hole in top plate or add shims to both bearings.
Exactly. Smaller diffs like the Slipperential need shimming. I may modify the front mount on the next batch for easier use(I have an idea to make fitting various diff sizes much easier), but the product as it is was meant to be "universal fit" - it doesn't fit any diff specifically, but should allow most every diff with proper shimming. I would suggest shiming both sides of the diff - about 1.5-2mm per side should center it up nicely. If you drill a new top plate hole, the mounting template would be null and void. :)
What's_nitro? 02.24.2010 01:55 PM
Perhaps Mr. Monster Mike would consider selling a top plate specifically to fit the Slipperential? :whistle: :yes:
BrianG 02.24.2010 02:12 PM
But like Mike said, the actual mount holes in the chassis would need to be re-drilled as well...
If anything, maybe he could make a bearing spacer...
What's_nitro? 02.24.2010 02:17 PM
I was thinking from the perspective of a completely custom installation. If someone was making their own chassis and such.
pinkpanda3310 02.24.2010 07:14 PM
I don't mean it to sound like a whine. I just automatically thought the universal slipdiff would be a direct fit to the universal cd mount.
I do have the nouse to make this work. I was just a little surprised and thought other members might like to know :tongue:
RC-Monster Mike 02.24.2010 08:00 PM
I considered matching the mount to the Slipperential, but didn't want to alienate all those larger diff users out there. The Slipperential is "universal" because its small size allows it to fit where most other similar units(diffs) are installed. The 3 piece motor mount is "universal" in exactly the opposite manner - it is large enough to accomodate the larger variants of the center diff.
Finnster 02.24.2010 08:03 PM
Why not make a top plate with an additional mounting hole ~4-5mm back?
Not much meat left to drill a hole to much further back in the original.
The drill template can then have a couple different drill holes depending on the mounting style.
1st gen stuff always has some growing pains, but I lookig forward to the next batch.
What's_nitro? 02.24.2010 08:07 PM
It just occurred to me that it wouldn't be too difficult to make a new top plate myself. :yes:
RC-Monster Mike 02.24.2010 08:10 PM
4-5mm would probably be too far back for many diffs - there is less than 4mm difference between most diffs and a 3.3mm hole that is 4mm offset from another 3.3mm hole is practically a slot. :)
RC-Monster Mike 02.24.2010 08:14 PM
The easiest way to modify would be to simply shorten the legs on the existing top plate - I made the legs long enough and drilled and tapped the holes deep enough to allow this as an option. If you remove a known amount and move the mount holes for the front the same amount on the template, you have a smaller package that fits smaller diffs directly. :)
