-   -   i need help (https://www.rc-monster.com/forum/showthread.php?t=260)
Stick15 03.07.2005 05:09 PM
i need help
hi im rob,
i have been running RC cars for a few years now, but i have always had nitro's.
i have blown a few engines now and felt like running some electric RC Cars/ Trucks.
:o please dont laugh :o
i now i have a CEN fun factor Rally, and i want to put a brushless set up on it. i have already put a single speed tranny on it and is just waiting to put in a motor.
here is the problem!
i dont know what sort of motor to put in.
or what kind of speedcontroler.
so please could any one help.
any info would be greatly apreciated
Rob
(stick15@hotmail.com)
MaxxFusion 03.07.2005 08:49 PM
How many cells will you be running?
RC-Monster Mike 03.08.2005 12:15 AM
I am not too familiar with this particular vehicle, but I would imagine any 1/10 truck powerplant would work well. I would start with answering netmans question. From here, some gearing would be helpful to determine the reduction in the car (even letting us know the stock gearing and set-up would help). No doubt there will be a few systems you could choose from, depending on what your plans are (bash?Race?street running?). Welcome to the forums, also. :)
Stick15 03.08.2005 05:11 AM
thanks for your help so far.
i plan on running 8 cells. ive been talking to a friend of mine and he has suggested running a setup such as a Feigao 8S motor withe 8 cells and a Warrior 9918 controller. would this run ok? i just want to make sure i don't blow a load of money on the wrong setup.
the car's stock final drive ratio is 9.71:1, but i want to run 2.2" tyres in the near future...hopefully i'll be able to up the ratio.
Here's a link to the car:
http://www.cenracing.com/cars/ff/ff4wd.html
although that's the link to the mt2, my car is the rally version and uses the exact same chassis and everything...but with shorter suspension arms and tyres. and my car has the single speed, so braking shouldn't be a problem.
oh, and i'll be using it for bahing during the week, but i'll be racing it at the weekends. I'd just like to have plenty of torque and a top speed of over 40mph....as fast as possible really!
thanks for all your help!
RC-Monster Mike 03.08.2005 09:00 AM
The 8s and warrior controller or MGM controller will both work fine for this vehicle(although I couldn't get the link to work). If you plan on running less than 8 cells, go with the MGM controller. If you may go over 12 cells, then the warrior becomes the only option.
Stick15 03.08.2005 09:47 AM
cen fun factor
this one should work now.
soz for the last one, i put it the wrong way round.
i am running the rally versoin not the MT but it is the same chassis. and i already have put on a single speed tranny so it would run direct from the motor.
thanks again
rob
RC-Monster Mike 03.08.2005 01:13 PM
That link worked. It will probably require some mods on your part, but the Lehner basic xl series or Feigao "s" motor will probably work quite well. I would go with the 8s Feigao for some extreme performance, but for better runtime, a basic or basic xl with lower rpms will be a better choice. On 8 cells, the 3600xl should be a great choice or 3600 basic, but these are not in stock). The 3100 would probably work quite well also.
Stick15 03.08.2005 01:22 PM
thanks for your advice.
what sort of mods do u think i will need
as im open for sugestions. i want this to be the first of its kind.
studysession 03.08.2005 04:05 PM
I like seeing it when people do conversions. Have you designed the motor plate yet?
Stick15 03.08.2005 04:40 PM
No, not yet
I am waiting to decide on what brushless set up I intend to use.
I intend on using either a 4 or 5ml aluminium or steel plate depending on prices of metal.
I will make a few disigns and put them on the brushless forum.
I am planning to make the motor plate within the next few weeks as I am busy at the moment.
Thanks for the kind remarks
Rob
RC-Monster Mike 03.08.2005 08:07 PM
aluminum will be plenty strong and much lighter than steel. Can you post a few pictures of your truck to this thread (without the motor)? Perhaps some of the members here can make some suggestions to assist you in your project.
Stick15 03.09.2005 03:18 AM
yer no prob, il get sokme pics asap.
just need to find my cam. :)
when its going il put a vids on it as well.
just wonderd, when designing the motorr mount to fit in the CEN would i also be able to fit it into other nitro trucks, like my rush for example.
i think that it would be fine to do as the motor mounts are identical.
what does any one else think?
thanks for all replys so far thay have been a great help.
rob
Dagger Thrasher 03.09.2005 05:49 AM
I think this is gonna be an awesome project Rob, but you knw what I think already, lol! I wouldn't have thought you'd have any trouble with making the mount fit the Rush too. You might need to make alternative holes in the mount to mount it to the Rush chassis and adjust the gearing, but it should run work great.:D
Stick15 03.09.2005 06:02 AM
thanks Daggar Thrasher
i hope that both your truck and mine will be as good as we both hope.
maybe il give you a race?
what do u think??
rob
Stick15 03.11.2005 03:27 PM
here is a pic of the chassis.[IMG]http://img.photobucket.com/albums/v6...e/PCDV0073.jpg[/IMG]
