-   -   Replacement rotor for 1515 2200Kv motor ? (https://www.rc-monster.com/forum/showthread.php?t=26112)
BashemSmashem 03.08.2010 04:19 PM
Hello , I was racing last week and all of a sudden my truggy was acting like the driveline was binding and started making a weird noise , after the race I went back too the pits and started looking for the problem , gear mesh was correct , diveline was totally free , the motor seemed like it turned ok .
Put it all back together and started too run it on the stand , everything seemed ok but then when it gave it more throttle I noticed the motor shaft moving out like 1/4 of an inch !:cry:
So I took off the front plate and pulled the rotor out and it seems the magnet has seperated from the motors shaft and that was causing the shaft too move forward and come out of the rear bearing and would start too rub the coils inside the motor can !
Its never been over heated and the bearings are still in great shape ? Has anybody else had this happen ? Can I buy a new rotor from Castle or NUE ?
I dont want too throw it away cause all it needs is a new rotor ?
Bondonutz 03.08.2010 05:27 PM
Contact Castle Tech directly via phone, I'm sure they'll help anyway possible to resolve your prob.
nitrostarter 03.08.2010 05:35 PM
Yeah, CC is very helpful via the phone.
suicideneil 03.08.2010 08:44 PM
Got any red loctite ( or green, which ever is best for high-temp use )?...
Duster_360 03.08.2010 09:44 PM
Red loctite is up to 300F, green to 400F.
Use green - it's thinner and will wick into place better than red. One of greens intended uses is for securing press fit and slip fit assemblies.
BashemSmashem 03.08.2010 10:51 PM
I really dont think loctite is gonna do it here guys , the magnet is completely detached from the shaft , it moves pretty easily ?
Thomas Porfert 03.09.2010 05:24 PM
This shouldn't happen, ever. Please contact us in Tech Support at your earliest possible convenience. We will discuss options on how to get this replaced as quickly possible. If you have had it less than a year, we will get it replaced under warranty. Right now we do not have replacement rotors available, but they are coming very soon. Please let me know if you have any questions or concerns.
Thomas Porfert
Castle Tech Support
