-   -   Nitro clutch gear problem (https://www.rc-monster.com/forum/showthread.php?t=26114)
jchrisj 03.08.2010 05:21 PM
Hi All,
My savage 4.6 X shreded the teeth on the clutch bell, (metal spur gear), I changed the bell and checked everything over, all seems ok.
However The 2 speed tranny doesnt change to second unless its lifted of the ground. Put it back on the ground, and it races of ok, just wont change up. Waiting to catch the piston comming out of the cylinder head.
I know i'm old fahioned here not wanting a bl electric but i live in England, and love the smell of nitrous for breakfast.............Its cheaper than napalm.........LoL
The new clutch bell was found at the back of my toolbox, but was an hpi stock item.
Any ideas greatfully received.
Cheers
Chris
scarletboa 03.09.2010 01:07 PM
get an hpi vented clutch bell. they are hardened and won't wear out like your stock clutch bell did. the stock gears are 17/47. if you are using a bigger spur gear, you will also need a bigger clutch bell to get the same top speed.
also, you can look in the instruction booklet and it tells you how to adjust the shift point in the transmission. you can set the shift point lower, so it shifts easier.
jchrisj 03.09.2010 01:22 PM
Hi and thanks for your reply,
I am confused as to why the shift point has changed just because i changed clutch bell.
Like the idea of the vented bell, me needs one of them.
Thanks
Chris
Overdriven 03.09.2010 03:40 PM
Maybe your clutch is slipping because the bell you pulled out of your box was contaminated or glazed over. This would cause the motor to rev up and not shift under load. Take away the load by lifting the truck in the air and the clutch isn't working as hard, so won't slip as much and will be able to drive the trans fast enough to shift. Take the bell off and use some sandpaper to rough up where the clutch shoes contact it. You can also scuff up the clutch shoes a little and use some degreaser on everything to make sure there's no oil on anything. Double check the slipper clutch too, if it's slipping to much you'll have the same problem.
jchrisj 03.09.2010 04:33 PM
Thanks, will look through what you have said,
Cheers
Chris
ratpower396 03.24.2010 02:13 PM
if you change the gear ratio it will change the rpm which in turn changes the shift point.. If you adjust the shift point it will be back to normal..
jchrisj 03.24.2010 02:27 PM
Thanks for that, but i realisd..............2 weeks later...........the gearing was out. as soon as i put the proper cog on it was back to normal.
Chris
