Losi LST E-Conversion Kit
Saw this over on the RCCA forums this morning. Looks like a great alternative to the TDR stuff.
EDIT: Actually, upon further looking, it appears like this may only work with a 36mm motor which makes it less than desireable. Boo! Edit again: Make that 39mm, not 36mm http://losi.com/Products/Default.aspx?ProdID=LOSB0017 http://losi.com/Content/ProductStati...17/chassis.jpg |
Good for an easy conversion on a measly 3s.
Battery behind, motor behind, ESC behind -> fail. You won't be able to give 30% throttle and it will already flip backwards...
Looks like some good thinking went into this! Losi is definitely trying to get in line with Traxxas and HPI with electric MT's. However, they are thinking wrong. Why don't these companies look to forums of actual users, and places like here that pioneered the electric conversion? I don't get it. We have done practically all the research and development one could need...
Anyways, cudos for their 2 steps in the right direction, and boo to the 1 step back... |
Wow, could they get that battery pack any higher. Did you see the pics of all the wheelies? Thats what happens with all that weight at the back and up in the air. :whistle:
Thats also what sells to the uneducated... |
I looked through the assembly instructions and noticed something that I may have been unaware of - does the LST tranny also have a built in center diff?
Thinking more on this conversion. Ditch the two speed part of it (and loose the reverse servo), lock the tranny, and put that battery case up front over the steering servo.
I'm not sure if its really limited to the 36mm motors - that looks to be more of a heat sink - and they show you layering tape on the motor to get it to fit. |
Looks like the kind of conversion typically done by a certain other company. Won't mention the name but it starts with F and ends in Design. :whistle:
This conversion is a joke... |
Really? Wow, that wasn't very smart of them then if they do in fact only allow 36mm motors.
I looked through the entire thing, and didn't see any mention of motor size limits, or even a reference to the dia.
| All times are GMT -4. The time now is 06:00 PM. |
