Neu motors not as good?
I have a 1515/3d spoil due to short wires internally. Repair won't be cheap, it makes me think that neu motors are not suitable for off road as it has a wire issue.
Should I just use it as paper weight or repair it? I am currently using my spare tekin 1550kv. No issue. I am trying to sell my 1512/2.5 but no luck also, seems that neu hand madr motors are not as good as neu castle as they are build for cars? I am Disappointed. |
Neu motors were designed for air applications hence Castle improved it more for land applications.
Send me your motor so I can use it as a paperweight in my office. |
You could repair & resell it, but I'd be suprised if you made much money to recoup the repair fees- depends what Neu say about the failure after they inspect it- if they say it will cost alot of $, you can either pay them, get the motor sent back un-fixed, or tell 'em to keep it ( they will repair it if possible then resell it as a reburbished item ).
Ditto on what George said though, the neu design was never intended for cars and truck, so castle addressed the issues to make a more suitable motor for ground use.. |
Lol wat a expensive paper weight! I was told usually the cost will be half on the cost. How much is a square can 1515/3d?
Theres only one place I know that sells those, and they only have a 1515 1y for $99 ( must be getting rid of that line up or something ? ).
I'd contact neu and see what they say about your issue- wires shorting on the can has been fixed with newer neus by adding rubber grommets around the wires where they enter the can. Otherwise I think you're looking at maybe a tekin motor possibly for ~$170, or a used medusa if you get really lucky- Linc probably has something suitable for sale, you know what hes like for collecting motors :na: |
Lol linc sold me this motor, It was working great till now. I pm linc but no reply. I will mail to neu n see what they say.
So far I hv a mint medusa 1600kv n tekin 1550kv. |
Thats irony for you :lol:
If it was working fine when linc sold it to you, I'd say its just been worn down through use- you might get lucky with neu saying they will warrenty it, you may not. The other motors you have look like good canditates for 5 or 6s lipo, just gear accordingly- the medusa may suffer the same issue in future though if it has the wires coming out the back, so its worth adding some insulation to the wires either way- I dont like that they are tinned their whole length either, makes adjusting them kinda hard. |
When he sold to me was ok, but less than 1/2 year with 1 race per month. If broke down:(
I hope neu won't charge me much if not it won't be worth it. I got my medusa us$75 so ok for spare. |
it is usually 50 bucks for the winding, they used to do stuff for free, then along came medusa/castle/tekin, nobody is buying this size of neu motors anymore, why when you can get a new tekin for 140 shipped?
Where can u buy tekin for $140 shipped?
towerhobbies.com with their discounts you get 25 off plus free shipping
Mine is tekno square can. I was told it's the same just the can change, the wiring problem is still there.
The neu motors aren't really intended for cars. Mine fail twice, both for the same problem...internal wires shorting out. And my motor is supposely updated rubber gormmet version. First time, they fix it for free since it was under warrenty. The second time they charge me $80. So I guess you can use that to factor in what you want to do with it.
BTW, stormerhobbies sells the tekin motor for $140. Or you can just get a CastleNeu, cheaper, none of those fail on me. |
I will send it in, after repair I will sell away. I rather buy tekin it's cheaper.
| All times are GMT -4. The time now is 10:32 AM. |
