Houston we have a problem
So I have a castle neu 2200 with a pinion stuck on it. The set screw is completely stripped and I have no way of getting it off. I want to run my truck but not with this bumb a$$ 9xl what should I do? ( I have no demmel)
No drill to drill out the set screw?
Do you have a handsaw?
You could try to get a slot into the set screw and get it out with a flat head screwdriver. Or you could try a slightly bigger torx and drive it into the striped set screw with a hammer to unscrew it. |
I suggest you buy a Dremel tool. :smile:
Usually you can pry the pinion off the shaft (slide it off the front).
i had to cut my pinion gear off the shaft with a dremel. it was the only pinion gear i had besides my (now broken) rcm gear that i had just gotten that fit and wasn't worn out.:no:
Google > 'pinion puller' = :smile:
So i think I'm going to go with the pinion puller!! Thanks guys.
if you have a drill press (vertical drill, whatever) and a good one, not just a toy dremel one or a hand drill stuck in a holder one, a manly bench mounted one. you can actually fabricate a pair of struts that sit across under the pinion and then using the drill press with an up-side-down drill in it, you can push the motor/shaft away from the pinion. this is how i do it but i have access a lot of large machinery, a nice new lathe is comming soon, 2.5 tonns of awsomeness (spins up to 2ft diameter jobs :intello:) |
OMG!!!! How did you do that??? |
i jus dunno what, alloys on my nissan manette just wont look right without lowering it...and you cant lower front leaf springs i dont think :no: 2ft wheels for the revo :yipi: heavier flywheel for my next car. gonna be sick!! |
Sorry, its a secret, used by evil people to pown noobs... :lol: :wink:
| All times are GMT -4. The time now is 03:50 AM. |
