-   -   Do you set your throttle EPA to 100%? (https://www.rc-monster.com/forum/showthread.php?t=26185)
superek4 03.14.2010 11:39 AM
I was racing for 1year with 50% throttle EPA, today I tried 100% the truggy can wheelie even with slip diff.
Do u guys do 100%?
wallot 03.14.2010 01:32 PM
yes.it is all about throttle control
E-Revonut 03.14.2010 01:46 PM
My throttle endpoint is set to 125% or whatever the max is on a DX3R. It's all about throttle control
BrianG 03.14.2010 01:52 PM
I keep mine at 100% as well. And I agree about throttle control. Also, keep in mind that radios have so many throttle steps from 0 to 100% and if you run at 50% EPA all the time, you lose a lot of throttle resolution.
superek4 03.14.2010 10:30 PM
Thx guys seems I hv a new toy to play wo spending. The truck is insanely fast n if I can control this breast! Winning races is no problem:)
So far I m using 6s 3000, tekin 1550 n slip diff 46/14 with CRT x2.
simplechamp 03.15.2010 05:38 PM
Doesn't that kind of depend on when you set the EPA and when you calibrate the ESC? Say you set the EPA to 50% then calibrate, you would still be able to reach full throttle, but your resolution of steps would be cut in half like you describe. But, if you had your EPA at 100% then calibrated then afterward turned it down to 50% your resolution would remain the same, but you'd only be able to reach half throttle.
The latter sounds like what superek4 was describing, since he experienced such an increase in performance after switching back to 100%.
Does this sound right? Or am I looking at it wrong?
BrianG 03.15.2010 05:41 PM
Yes, I wasn't talking about "range", I was talking about resolution, or steps between each throttle point.
