Good rule of thumb?
Ran across this elsewhere; by overgear I'm assuming that it means too high of gear ratio, undergear means too low of gear ratio. That sound right?
Hot motor, cool controller, cool batteries = undergeared Cool motor, hot controller, hot batteries = overgeared Warm motor, warm controller, warm batteries = happy components Reason I ask is that I had overgeared my XXX-T slightly when switching to brushless and the motor was getting hot. So the solution was to lower the gear ratio by going to a smaller pinion. So this seems a bit backwards, or I have my under/over definition wrong. |
Yeah, the definitions are a little mixed up there.
As a rule of thumb those guidelines are correct, but there are always exceptions top the rule:-
way over geared - hot everything motor too small/ underpowered = will run hot regardless of gearing etc etc. What motor & kv & voltage were you using?... |
Mmms. Ok. Well, as far as the XXXT, its a 5700/MM running 30C 4000-4200MaH batteries 2S batteries (from variety of sources). I honestly don't remember what the original gear ratio was that I missed, but basically I scratched it went and figured out the overall ratio for the Firestorm Flux and then used the same overall ratio for the XXXT which resulted in a lower gear ratio. That dropped the temps on the motor to the acceptable range.
Well I finally got batteries and all together and took the RC8T out for a run.
MMM/2200 using 50/16 gearing and 5S 5800MaH (Zippys). Motor was up to around 140 after some long high speed passes. Batteries were around 90. But the MMM fan came on. Thoughts? Quote:
Doesnt sound too bad- what speed is that geared for with your setup exactly ( I would pump the numbers into the calc but Im lazy :P )?
Doing speed runs will heat things up a bit more vs normal bashing argueably, so I wouldnt be too concerned- just allow the motor and esc to cool down every now & then between runs, then bash/ speed run some more. :) |
52.62mph is what BG's says. I was going with it because people were mentioned it was a good combo.
Was gonna try going down to 50/14 which is a "46.05". I will say though, belting the tires (I did the insides with gorilla tape and outsides with 50lb test fishing line) means very minimal if any ballooning! Quote:
| All times are GMT -4. The time now is 01:54 PM. |
