-   -   Cc 2200 Bearing Size? (https://www.rc-monster.com/forum/showthread.php?t=26238)
brushlessboy16 03.17.2010 06:54 AM
What size bearings do the big castle motors use?
Benji 03.17.2010 01:42 PM
Not 100% sure, 5mm x 16mm x 5mm
Thomas Porfert 03.17.2010 04:06 PM
+1 for Benji. 5 x 16 x 5.
andreazinno 03.18.2010 01:16 PM
Hi, same size also for 1520 ?
Bye, Andrea.
suicideneil 03.18.2010 07:19 PM
I believe so- its the same diameter motor and shaft, just longer.
Thomas Porfert 03.18.2010 11:20 PM
I'll double check tomorrow and let you know. I'm pretty sure neil is right, but I want make sure. I'll get this information posted on our website as well; it should have already been there. My bad. :oops:
Out of curiosity, were you needing new bearings for the motor? So far I have heard of less than a half-dozen bearing failures with these motors; just making sure there's not a problem we don't know about or if you're just stocking up to be safe. :smile:
Thomas Porfert
Castle Tech Support
andreazinno 03.19.2010 04:50 AM
Thomas Porfert
Castle Tech Support
Hi Thomas, my question was just for curiosity and, eventually, to get some bearings to be used as a spare.
Besides, I wonder whether I can get some hybrid bearings (for example the ones from Boca Racing) to have even better performance with respect the factory bearings.
Bye, Andrea.
Thomas Porfert 03.19.2010 06:04 PM
All of the 1500 series motor share the same size bearings; 5mm x 16mm x 5mm.
Thomas Porfert
Castle Tech Support
