r1 and hotwire problem:(
I ınstalled my new received hotwire and made the settings. But when I unplug it all the leds of the esc is open at same time but not full bright. It's not arming and I can't calibrate it. My OS is windows xp and I think I did eveything right for installation. When I plug the esc to hotwire again my settings returns to default. My esc is not operating now and I need urgent help :(
try updateing the firmwire, its under the advanced tab...
you did plug it back into the RX, right?(everyone has done it):oops: |
off course I plug it back:)
What should I do to update it? If open the advanced tab there is some numbers like 198 , 200 but I don't know what to do.. Edit: I figured it out. Problem solved. Thanks for help.. |
Yes. Last time before problem I've been cancel upgrade session premature..
| All times are GMT -4. The time now is 04:05 PM. |
