-   -   Can't calibrate DX3R/DSM2 combo with Mamba Monster (https://www.rc-monster.com/forum/showthread.php?t=26275)
Flip 03.20.2010 01:19 AM
Strange things happening. DX3R binds with either DSM2 or DSM1 receiver. BUT when i try to calibrate with MM it does forward ok, then reverse ok, then will eventually do neutral after a longer peiod of time than normal!
The ESC then arms, but goes nuts, just like a run-a-way AM... no way to control it !
My old DX3 binds with the DSM1, calibrates ok, then ESC arms and works well :-)
I know the DX3R is ok, because I use it on another model with similiar specs !
Anybody run into similiar problems?
shaunjohnson 03.20.2010 01:25 AM
well actually, i did get it to calibrate neutral but when the ESC armed it went absolutely mad!! full forward, full reverse, full forward.
might i also add that the servo was also playing up (full left, full right). but not with DSM1 operation.
even when a DSM1 receiver was used with a DSM2 transmitter.
crusey_aus 03.20.2010 04:49 AM
I've have similar issues with Mamba Max / Spektrum DX3S combo
Only way to get it to calibrate was to rollback the esc firmware
Castle are apprently looking at it there is an old thread discussing it here
http://www.rc-monster.com/forum/showthread.php?t=24984
Cheers
Flip 03.20.2010 05:36 AM
Thanks, crusey_aus,
That is exactly my problem.. couldn't find it on the forums... but thanks again. :-)
Flip 03.20.2010 06:10 AM
Tried reverting to firmware V1.20... but same problem occuring... binds OK, calibration does fwd & reverse OK... but strange things still happen when calibrating the neutral position...
magman 03.20.2010 08:49 AM
That is odd..I have a 3S and mmm w/newest firmware and had no issues. followed directions to a tee and done..
BashemSmashem 03.20.2010 09:24 AM
I have 3 different MMM systems all running off the same DX3S and had no trouble binding or calibrating them . Check too see that all the trims are at zero before you try too calibrate .
E-Revonut 03.20.2010 03:46 PM
May be the rx
Flip 03.20.2010 04:12 PM
Checked all trims were zeroed at time of calibration. The problem is there ONLY with the DX3R with either the DSM1 or DSM2 rx. Problem NOT there with the DSM1 and plain DX3.
Racing a little later on this morning, so don't wanna stuff around with it anymore today. Will tinker when I get home this afternoon :-)
fastbaja5b 03.21.2010 11:45 PM
Seems to be an issue on radios that use a faster frame rate. Had no issues on a DX2, DX3, DX3E or DX3S but a DX3R and a KO EX-5UR all needed the ESC to go back to V1.20 firmware to calibrate.
