-   -   Council report to avoid overheating (https://www.rc-monster.com/forum/showthread.php?t=26308)
galaxy76 03.22.2010 04:23 AM
1 Attachment(s)
I have a E-Maxx + MM with the motor 2200kv castle creation. would like to play without worry of overheating on both asphalt and dirt with a good speed. i use 5 lipo cells. currently 68T and 21T pinion. What do you recommend
besides. But what is this?
fastbaja5b 03.22.2010 06:59 AM
MM on that motor will overheat, are you sure you are using the Mamba Max and not the Monster?
galaxy76 03.22.2010 07:50 AM
mamba monster
magman 03.22.2010 07:54 AM
Just be sure to check your diffs for proper shimming. On 5s, you will tear them apart quickly if not shimmed correctly. Other than the diffs, just watch temps
bruce750i 03.22.2010 12:00 PM
Opti-drive sensor door for nitro tranny?
suicideneil 03.22.2010 03:09 PM
^ That, If you remove it you can see the little pins on the output gears that the sensor would count- traxxas are just cheap and recycle parts & molds etc.
And FYI ( @ the OP ):
MM = mambamax
MMPro = mambamaxpro
MMM = mambamonster(max)- the 'max' part was dropped officialy, but lives on unofficialy in order not to confuse people between the MM and MMM. :wink:
