8ight T diffs in 8ight BL
I cant remember where i read this but I thought I heard something about people running the truggy ring and pinion in there 8ight BL buggy conversions instead of the buggy gears? Does anyone know anything about this? Putting together a 8ight 1.0 now with a mamba monster 2200 kv.
The reason for doing this was so you could run a reasonable size pinion spur combination if you were using a motor with a KV too high to otherwise gear correctly. Like in the early days of brushless with guys running the 3000KV Neus on 4S.
You shouldn't really need to do this with a 2000KV motor (unless you are running it on 6S). However, if you do want to do it, I have a brand new pair of 8 truggy diffs I'll sell you a reasonable price. (I at one point had too high a KV motor but it needed service anway so I just swapped it for the right KV when I sent it to Neu for repair. So I never used the truggy diffs.) |
Yeah, with proper KV and voltage, you shouldn't need to anymore (only real difference between 8 and 8T diffs is a 13/43 and 10/43 gearing combo).
ok cool thanks for the input guys
The diffs for the 8b and 8T are the same part No. Same deal with the gearboxes. Only the ring gear and pinion gears are different.
| All times are GMT -4. The time now is 11:24 PM. |
