Servo Current Draw ?
if my 2wd stampede weight about 5lbs 10oz and the front tire are 4.27inch of diameters and the both front wheel/tires weight 330grams how much approximately the steering servo can draw on the main battery if ( ex : if I run the car for about 40min ) ?
here the specs of the servo : http://www3.towerhobbies.com/cgi-bin...&I=LXVEP2&P=ML |
Any servo with properly adjusted endpoints will not draw much at all. I experimented once with a multimeter and while "sawing" the wheel back and forth saw 200milliamp spikes on a similar servo properly adjusted. On a 9000T with endpoints that reached too far the spikes were closer to 1amp. Properly adjusted the spikes were under 300milliamps.
ok but I ask because I just want a estimation on how I can use mah on the main batteries with about 40min runtime.. do it value it to use a external 6v pack to power the servo does I would notice a increase in the runtime ?
The difference is going to be negliable. You'll have a hard time measuring any difference in run time just because variations in how much throttle you use on each pack will have more of an impact than the servo + rx draw.
To give you a better estimation, my 1100mah 6v rx pack I used on nitro cars would last at least an hour with two servos drawing on it. If you have a multimeter, just hook it up inline on the red or black wire of the servo (or the esc to see the rx+servo draw combined) and you'll see what it'll draw exactly. It's not much and I doubt it would make a difference of more than a minute or two. |
in my old, nitro savage, i used to get a full 4+ hours out of my 1600mah rx pack. the servo will draw maybe 100-200mah at the most. it is only a 1/10 and the servos don't draw much current. |
And if you using a switching BEC (either external or built into the ESC), the actual current drawn will be even less than the servo current.
im using the BEC built-in in the 1/10 mamba max esc
That's a linear BEC, so whatever current draw the servo draws comes directly from the battery.
A switching BEC is more of a "power transfer", so the higher the battery voltage is, the less current is drawn for a given servo draw. Ex: 5s battery and 1A servo @ 6v. 18.5v/((6v*1A) /80%) = 0.4A BEC current drawn from the battery. The 80% is a typical BEC efficiency figure. |
Man, this is a bit of an eye opener. My heli servos can pull 2.2A each. Had to get a CC BEC Pro to handle the amp load (shut down in mid-air = epic fail). I suspect most properly adjusted car servos are under an amp.
| All times are GMT -4. The time now is 04:00 AM. |
