FS: Running gear from my Savage--Neu, MMM, Elite Lipos, Hacker, Nomadio
I'm selling this stuff of for what I think are cheap prices. If you don't like my price, make an offer. Straight to it:
First is a Neu 1521/1.5d/s (1900kv). Used, always had foil tape protection from dirt, has a hand ground flatspot on the shaft and a slight rounding off of the shaft on the end where the previous owner had a prop coupling slip. One wire has a split in the insulation too. Runs like a raped ape. Also a Hacker B50 8XL (2000kv). These motors are great--alot better than the Feigaos that copied them. This one runs well, but is not in the best cosmetic shape. Also have water jackets to fit it or any other 36mm motor. Can't forget about the MMM. V3, I shortened the power wires quite a bit to accommodate my setup--make sure it will work for you. http://i293.photobucket.com/albums/m...s/DSC00748.jpg Elite 5S 5300 30c lipos. These are top rate packs and hold many boating records. They are quite a bit longer than normal. 10 cycles on them and always balance charged on my Duo at no more than 1c. http://i293.photobucket.com/albums/m...s/DSC00749.jpg And my Nomadio Sensor. This is hands down my favorite radio ever. Includes one V2 receiver (with nicks in the outer protective sheath over the antenna--doesn't affect performance) and a complete set of sensors. http://i293.photobucket.com/albums/m...s/DSC00745.jpg |
| All times are GMT -4. The time now is 01:03 AM. |
