MOD 0.8 Spurs...
Hi,
Can we get bigger then 58T MOD 0.8 spurgears? |
We have 65t mod.8 gears available in Delrin now. Great for truggies at about the same OD as a 52t mod1 gear. 58t mod.8 are also available in Delrin now, along with 50t mod1 in Delrin. :)
Great work with the new gear offerings. Will these be listed for individual purchase soon?
Yes, they are now options under the Slipperential spur listing. :)
Will the 65T fit the XT8e?
Use BrianG's gear size calculator to determine the diameter and compare it to what you are currently using or the stock XT8 spur.
Stock is 48, 65T mod 0.6 is same size as 52T mod 1.:intello:
i dont have my conversion kit yet.:neutral: |
| All times are GMT -4. The time now is 12:49 AM. |
