-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   3905 differential question and aftermarket help... (https://www.rc-monster.com/forum/showthread.php?t=26470)
DwightSchrute 04.02.2010 10:41 AM
i'm about done with my 3rd differential on my g-maxx. it's a 3905 diff, and i keep stripping it. i went to a spool, but broke that too.
is their any aftermarket/buggy diff that i can use in the stock case?
or what do you recommend for an aftermarket diff? and what diff case do i need?
everything else on the truck has been rock solid, but this diff issue is quickly becoming a pain in my ass.
any help is greatly appreciated.
nitrostarter 04.02.2010 10:51 AM
I don't think any buggy diffs will fit the stock Maxx cases.
Cheapest route would be to install some LST diffs.
Nicest route would be RC-M V3 diffs.
suicideneil 04.02.2010 01:16 PM
The RCM diffs are for the revo :wink:
You have 2 options:
UE ultralites or VBS
Modified LST2/ muggy diffs
Option 1 is $$$ but will last forever, option 2 is $ but does require a little bit of work- but only a little & will also last forever ( use the metal diff cases and metal collar.. ). Here is an excellent guide:
http://www.rc-monster.com/forum/show...t=9153&page=15
DwightSchrute 04.02.2010 02:19 PM
thanks, much appreciated
E-Revonut 04.02.2010 03:03 PM
Flm does make hybrid bulkheads to run 1/8 diffs in a maxx. They are available right here in the RC-M store
suicideneil 04.03.2010 03:10 PM
Ah yes, I forgot about option 3... :whistle:
DwightSchrute 04.04.2010 07:59 AM
if i went with the flm bulkheads, which buggy diffs (also/ring and pinion?) would be a good choice?
suicideneil 04.04.2010 02:01 PM
The hotbodies buggy diffs are great ( I have them in my UE ultralite cases ), if a little pricey- Mike sells a kit in the rcm store that includes the pinion and bearings required too. Otherwise, anything ofna makes for 1/8 buggies is fine and cheaper too most likely- 43/13 being standard buggy diffs ideal for the maxx in 2nd gear. If you went with a center diff however, the 43/10 truggy diffs might be a better choice- you can always play with BrianG's calc and see what works best for you.
DwightSchrute 04.04.2010 02:15 PM
thanks. i think i'm gonna go with the flm hybrids and the hotbodies diffs. it's a little pricey, but the traxxas gears aren't cutting it anymore and i think the buggy diffs will be alot more economical in the end. much appreciated.
simplechamp 04.04.2010 04:42 PM
Do the HB hardened steel diffs have just the hardened steel outer ring gear, or do they come with the hardened steel internals too? I'm trying out some of those hardened steel internals in my Slipperential once they arrive, should be able to take a solid beating compared to the cast alloy ones.
suicideneil 04.04.2010 09:44 PM
Good question- I have no idea :lol: Never ever seen any broken internals though, just one mangled cup and a loose bit of metal shim- tough diffs... :yes:
Bear in mind though that the slipperential uses a slightly smaller than normal set of internal bevel gears- like the crt .5 has or something of that nature, just incase you werent aware or were planning on using normal sized 1/8 internals ( unless Im trippin again ).
George16 04.04.2010 10:48 PM
The Hot Bodies diff come with hardened internals also. The Ofna Violator Pro buggies use hardened steel on both the ring gear and internals also.
simplechamp 04.04.2010 11:23 PM
Good to know. I hate rebuilding diffs!
