Rc8
Does any have the gearing for an rc8 to add to Brians calc. Thx
RC8 buggys use truggy ratios IIRC.
10/43 = 4.3 |
correct, The RC8 uses 43/10 gears in the diffs
Really - that would seem that I need to gear up to 18T but my friend is saying more like 12T!
What motor/esc/lipo?
MMM 2650kv 4s calibers
I run 1700kv with 46/17T on 4s in my RC8T so judge accordingly...
This is the buggy not the truggy...
Right, but you could plug my settings into the calc and slowly transfer everything over.
Gotta use a little imagination Arct1k :na: |
I run 50/16 or 50/15 in my Rc8T with the cc/Neu 2200kv. Great bottom end as well top and my fan never even kicks on the esc.
Yes it uses Truggy diffs in the rc8. At least mine does.
Pinion Speed
10T 26.54 mph 11T 29.20 mph 12T 31.85 mph 13T 34.51 mph 14T 37.16 mph 15T 39.82 mph 16T 42.47 mph 17T 45.13 mph 18T 47.78 mph 19T 50.44 mph 20T 53.09 mph thats the graph you want for the rc8 with your motor/battery combo id suggest a 14 or a 13 for a smaller track, for bashing a 17 or 18 sounds good |
16 seems about perfect for everything
| All times are GMT -4. The time now is 02:38 AM. |
