-   -   MMpro & 60mm medusa in a 1/8 Truggy? (https://www.rc-monster.com/forum/showthread.php?t=26513)
drkdgglr 04.06.2010 09:27 AM
I have a 1/8 Mutilator Truggy, MMPro, and a 60mm1300kv medusa. I'm thinking about putting the electronics in the Mutilator and gear for 20mph on 5s or 25mph on 6s. The truck would be for a kid, so it doesn't have to go any faster.
Do you think the esc&motor will work(not overheat) in this setup?
lincpimp 04.06.2010 09:43 AM
Yeah, amp draw should be pretty low. I would also set the punch control way up, like 100%. Should tame the wheelies!!! Or front tire unloading depending on what thickness center diff fluid you use.
drkdgglr 04.06.2010 09:57 AM
Thanks! I believe I have 30000 or 50000 fluid in the center diff.
el tomaso 04.06.2010 11:10 AM
I think thats a nice light setup, I am running MMPro and 60mm medusa 1600kv in my caster buggy now. I think that could truggy...
TG
scarletboa 04.07.2010 01:44 AM
that combo is perfect for what you are wanting to do.
