Tekin 2000kv in Aftershock?
Does any of you have any experience with the Tekin RX8/2000 kv truggy combo in an Aftershock/LST?
So far I have ran the MMM/2200 combo, which I have now sold. So the question is actually if the RX8 can handle the weight from the Aftershock. |
On 6s geared lower it should work.
Might want to stick with lighter wheels and tires. I found a 1521 1y on 6s would allow pretty much any tire choice. And the tekin is 1515 sized. |
So on 4 and 5s it would be better to stick with the MMM combo?
I used the MMM/2200 on 5s in a lst and it did fine, but I was running truggy tires on it. How hot does it get in Denmark?
Temps
I used to run the MMM/2200 combo as well, but threw it in my Savage, which I have now sold, so just wondered if the RX8 combos would do any good in it, now that I have to buy a new brushless combo.
In Denmark the temperatures rarely hit the late 80īs, but in the summer normally +/- 70 degrees. I run the truck on Proline 40 series Moabs. |
| All times are GMT -4. The time now is 06:33 PM. |
