-   -   How to charge a 8.4v rechargable square batt (https://www.rc-monster.com/forum/showthread.php?t=26555)
superek4 04.10.2010 09:25 AM
I need to charge a small 8.4v square batt 170mah nimh. I will use a Hyperion duo3 charger to charge it. What shld I set the charger on?
George16 04.10.2010 09:30 AM
Set it to Nimh and charge up to 1C.
superek4 04.10.2010 09:34 AM
It will auto cut off?
Bondonutz 04.10.2010 09:43 AM
You could charge it on 0.1amps, The lower the Amps going in the fuller charge it'll take.
superek4 04.10.2010 09:59 AM
Yes it can't do 1amp the temp went up to 50degree. I set to auto it's charging at 0.25amp now I use a fan to cool it up.
Btw the charger only has 100 or 200mah which is better?
superek4 04.10.2010 08:32 PM
Fully charge n managed to charge at 66mah into it.
