-   Crawlers/Scale Vehicles (https://www.rc-monster.com/forum/forumdisplay.php?f=35)
-   -   Cheap Brushless for Crawler ??? (https://www.rc-monster.com/forum/showthread.php?t=26592)
FastXR 04.13.2010 12:44 PM
So I'm looking for a cheap brushless system for my crawler. Has anyone tried the ez run 35 amp with 32T motor in a crawler? I have a basically stock AX-10 that I use around the house and bring with to races to goof around with between races, so I dont need anything big dollar or competition but I dont want complete junk either. It looks like the ezrun can have 100% drag brake and the 32T motor looks about right too, what are your thoughts?
Arct1k 04.13.2010 12:52 PM
Sidewinder and a small outrunner perhaps or a used 2s goat
FastXR 04.13.2010 12:55 PM
The ez-run won't get the job done? I previously had a Rooster and Integy 55t in it but traded the rooster for something else that I really needed at the time. I can get the ezrun combo for about $65 shipped? I have to think the sidewinder will run me more than that alone?
Semi Pro 04.13.2010 02:46 PM
sidewinder and a scorpion outrunner gets the job done nicely (scorpion is the manufacture that made the out runners for homes hobbies)
Arct1k 04.13.2010 03:06 PM
But you might as well get something that has support and will last when you want to get something better... I'd by Castle
FastXR 04.13.2010 03:26 PM
I agree that the castle would have the support and most likely be a much better choice, I was curious if anyone had tried the ez run.
So anyone got a sidewinder for sale cheap?
FastXR 04.13.2010 06:38 PM
OK so update here on this thread, I just picked up a used Mamba Max from Rawfuls on here, I think that will work nicely in my crawler (I hope so).
Can someone provide me with a link to a nice brushless motor, maybe the scorpion that was listed above or perhaps a part number for one that will work nicely on my AX-10? Im thinking of running on 2s, currently its setup for 6 cell Nimh, but if 3s is the way to go let me know and recommend motor for that setup. Thanks
FastXR 04.14.2010 10:44 AM
Arct1k, Semi Pro, anyone, what motor should I get to go with the MM in my crawler?
Arct1k 04.14.2010 10:51 AM
Check out holmes hobbies. Holmes is the man.
lincpimp 04.14.2010 11:21 AM
I like an 1100kv outrunner on 3s. My comp crawler had a 833kv motor on 3s, but it was a 28 series motor so it was a "bit" oversized. Finding an outrunner with a 25mm mount pattern and an 1/8 shaft is difficult, that is why holmes may be your best bet. Most 25mm pattern outrunners have 5mm shafts. I used 32p pinions and spurs on my comp crawler, but you have limited gearing going away from 48p.
I have used the small axi outrunners with an adapter plate to mount to the axial tranny. My little 6x6 tlt axle crawler does grreat with that motor. Pretty sure it is a 2217 1100kv motor. But you do need a 19mm to 25mm adapter plate to mount that motor on a axial/pede tranny. I made one out of a steel washer.
FastXR 04.14.2010 06:23 PM
So I'm best to go with the HH 1100kv revolver then? Im sort of confused though, will that bolt directly to my axial or do I need an adapter plate to match it up?
lincpimp 04.14.2010 06:44 PM
The holmes hobbies revolver should mate right up, 25mm bolt pattern and 1/8(3.2mm) shaft is what you need.
FastXR 04.14.2010 08:25 PM
Perfect thats what I'll go with then and run it on 3s. Thanks for all your tips guys.
lincpimp 04.14.2010 08:51 PM
No prob, I am full of tips (and hot air)
What's_nitro? 04.14.2010 09:07 PM
Just FYI, BL crawlers tend to cog quite a bit more than you might be used to with regular trucks. I would plan on adding a couple more capacitors and/or using a smaller pinion.
