Rckcrwlr's Savage Flux HP...or is it?
This project moved pretty fast. I saw this several months ago but was unsure of what it was about. Then last months RCDriver sealed the deal.
I would like to introduce you to... http://i168.photobucket.com/albums/u...5BFlux_004.jpg http://i168.photobucket.com/albums/u...5BFlux_005.jpg http://i168.photobucket.com/albums/u...5BFlux_007.jpg http://i168.photobucket.com/albums/u...5BFlux_011.jpg http://i168.photobucket.com/albums/u...5BFlux_012.jpg http://i168.photobucket.com/albums/u...5BFlux_014.jpg http://i168.photobucket.com/albums/u...5BFlux_015.jpg http://i168.photobucket.com/albums/u...5BFlux_016.jpg http://i168.photobucket.com/albums/u...5BFlux_017.jpg http://i168.photobucket.com/albums/u...5BFlux_018.jpg |
Enter Stage Left...
TCSCrawlers.com Savage Flux 5T conversion...Yeap you read right... http://i168.photobucket.com/albums/u...5BFlux_019.jpg |
The hardest thing to do was tear apart a brand new truck...but it brings back memories of the days we did it with crawlers before there were RTR, ARTR and Kits...
Having Savages in the past, I knew that they were easy to disassemble. Removed the body, and tires... http://i168.photobucket.com/albums/u...5BFlux_022.jpg[/URL] You probably think that this is just a pile of screws...actually they are laid out where they belong on the chassis...makes it easier to replace them. http://i168.photobucket.com/albums/u...5BFlux_024.jpg[/URL] One side off. For those of you that never worked on a Savage. It is a Twin Vertical Plate (TVP) chassis. They are a dream to work on. They disassemble easily. http://i168.photobucket.com/albums/u...5BFlux_025.jpg[/URL] Ten Minutes from out of box to this point. http://i168.photobucket.com/albums/u...5BFlux_026.jpg[/URL] |
Now to reveal the excitement...
Presenting the TCS Flux 5T Conversion Kit... http://i168.photobucket.com/albums/u...5BFlux_020.jpg[/URL] This crowbar is actually the front drive shaft...Getting the picture yet... 11.5" http://i168.photobucket.com/albums/u...5BFlux_021.jpg[/URL] |
The details and accuracy of the 5mm chassis is amazing.
Conversion Kit goes together as fast as it was disassembled. http://i168.photobucket.com/albums/u...5BFlux_028.jpg http://i168.photobucket.com/albums/u...5BFlux_027.jpg Add the bulkhead and windshield braces (Delrin) http://i168.photobucket.com/albums/u...5BFlux_029.jpg And the 8 chassis supports. http://i168.photobucket.com/albums/u...5BFlux_030.jpg |
If you haven't assembled it yet, get me a measurement on that shaft they included in the kit. Might need to buy one for my LST conversion.
It took me a total of 1.5 hours from start to finish.
Here it is mocked up with 5B Wheels and Tires. http://i168.photobucket.com/albums/u...5BFlux_032.jpghttp://i168.photobucket.com/albums/u...5BFlux_031.jpg Here it is with the stock tires (Waiting on adapters for the 5B Wheels) http://i168.photobucket.com/albums/u...5BFlux_033.jpghttp://i168.photobucket.com/albums/u...5BFlux_034.jpg |
How about some referencing???
Savage Flux HP vs TCS 5T Conversion (TCS Image) http://i168.photobucket.com/albums/u...n/PA120039.jpg Left 2.2 Comp Rig/Center Flux 5B/Right Super (That's right, its my Super) http://i168.photobucket.com/albums/u...5BFlux_035.jpg |
Waiting on the Savage Wheel Adapters...
Will also be adding the HD wideners to get it more proportional and handle better. Was planning on running 6s... What are your thoughts? |
very cool, how does it handle?
Hope to be able to run it this weekend...but only have two 2s LiPo's so I don't think it will be a real test... |
6s and a smaller pinion would be my choice. Gear for around 40mph on 6s and see how the motor does. Stock tires are not too heavy but I can imagine those 5t ones will add weight.
1.8 and 2.4lbs respectively.
I'm looking at 5S, as that is what I have for my truggy, running 47/17 (nitro conversion rather than Flux base) for ~40 on a 2200kV (for now). Quote:
| All times are GMT -4. The time now is 06:48 AM. |
