Cheat
I guess i should know but is cheat available on the MMM and orginal MM - If not why not?
Just wondering as at speed the mmp isn't using the sensors... Cheers |
IIRC, Cheat mode is a direct function of sensored-only operation. So, even in the MMPro, you have to be in sensored-only mode to use cheat (not smart sense).
+1, as to that is how I understood how the system works. |
Honestly, I don't know. I've never played with sensored operation during testing and since. Sorry. :oops:
Probably gonna have to wait for a CC rep for that level of questioning. |
Its just dynamic timing advance as I see it but not sure why this still isn't possible under sensorless operation to...
i agree i would love to here what Patrick or one of the other engineers has to say about it |
It's my understanding that the CHEAT mode enables timing advance at a certain RPM, or range of RPMs, and you need the sensor to measure these RPMs accurately.
Nah the ESC knows what RPMs it is at by the feedback from the motor - without that it wouldn't know when to fire each phase....
With sensors, you can advance the timing more aggressively than you can sensorless. It's MUCH MUCH harder on the motor and ESC, but in stock class racing, can make all the difference. I wouldn't try it on a high quality motor, just the junk they run in ROAR stock. |
High quality motors don't need a lot of timing to perform well. :lol: |
then we wouldnt have to race with red and bash with green:party: quick thred jack while i am here can the MM handle 144300rpm or are the shudders comeing from the poor motor:whistle: sadly the motor is running pretty cool for being that far over voltage |
| All times are GMT -4. The time now is 07:11 AM. |
