-   -   Doing my Homework for Twin Mamba Monster flux. (https://www.rc-monster.com/forum/showthread.php?t=26816)
Jahay 05.03.2010 12:41 PM
Ive decided to build a second racer carbon flux and have written my shopping list up for that........
But i do not want my DB-17 chassis to go to waste as i really like the stability it gives..... and so decided why not go a little crazy... and make it REALLLLLY FASSST :surprised:
I have seen a few twin motor maxxs and revos and custom stuff... But not a savage yet... I know a better idea would be to run a huge single motor on 10s but i prefer this idea. I just want people to point out potential problems i could run into and decent items that would work for me :yes:
I dont feel much would need to be done apart from finding a new twin motor mount (similar to the e savage, i guess) and then just moving around a few servos and adding battery boxes to the side... Oh and obviously the 2 motors and 2 Escs...
There is going to be a bit of custom work done but should be fun...
I dont know much about twin mounts that were used on the E-savage but can they house the neu 1515 2200kv motor???? I would never jump this thing, being afraid that the motors would be stripped from their mounts.
Now... apart from sourcing an appropriate motor mount what other potential problems do you think i could run into for ex... tranny probs?????
Some of you may think this is a stupid project but its not going to be my main savage... i just want to push the savage and see how far it could go :)
I know that a few people have pushed the savage to 80mph but that is with heating problems. So this is why i thought... If i share the weight over 2 motors... i should run even faster and maintain cooler temps...
I know this is the best place to come regarding motors so give me your advice!!!! I dont care if its good or bad... just lay it on me!
THANKS!
Jahay 05.03.2010 02:25 PM
Ive been speaking to dan at kershaw and he has offered to make me a custom mount. I have had to change my mounting ideas... and mount one motor on top of the other.
here are some pics i sent to dan, so he can get an idea of what needs to be done for the custom mount... I also asked him about possible interference of two motors and magnetic fields...??? any one got any input on this
http://i878.photobucket.com/albums/a...7/DSC00274.jpg
http://i878.photobucket.com/albums/a...7/DSC00273.jpg
JThiessen 05.03.2010 03:20 PM
Maybe...you should consider, or at least look at, a belt drive with that. Dont know where the heck you'd source a belt in the correct length.
nitrostarter 05.03.2010 04:00 PM
I see no problems with interference. There have been many dual BL's done. The issue become synchronizing them so that they are working together and in unison, not fighting each other.
I'd suggest getting a 1521/1Y and pumping 8s-10s through for some super high speeds runs. Dual brushless isn't always the fastest... but looks cool! :lol:
Jahay 05.03.2010 04:11 PM
what is the 1521 rated at kv wise... how many s can it handle and what sort of esc would be needed?
nuz69 05.03.2010 04:23 PM
1521 1Y is 1580kV, like the CC-neu 1520. It can handle 60 000 RPMS and a lot of power, so you just need a high voltage ESC to run it at your insane speeds :D :D :D
7 or 8S with the 1521 1Y should give you plenty of speed.
Keep in mind that many people use the 2200kV on 6S, you can as weel us the 1521 1Y on 8S with the same motor RPM, but a lot lot lot more TORQUE :D :D :D:lol:
Jahay 05.03.2010 04:36 PM
damn i should have bouught that motor from the beginning! looks like it may even be able to handle up to 9s if it can handle 60,000rpm! Still curious as to what kind of escs these use as this is out of my knowledge teritory...
ZippyBasher 05.03.2010 06:15 PM
Well if you had mechanical braking... Alot of HV users use the Castle Creation 110HV or even a HV140. But again you would need mech. brakes.
http://www.castlecreations.com/produ...hv_series.html
or even something from HobbyCity
http://www.hobbyking.com/hobbycity/s...dProduct=10332
Jahay 05.03.2010 06:24 PM
I use mechanical brakes... motor brakes are rubbish for feel when driving.
Could i even use these ESC with my current 1520??? couldnt a 1520 be able to handle up to 8s??? or is that too much???
thanks for the links zippy!!!! they are some impressive speed controllers!
suicideneil 05.03.2010 07:43 PM
1520 is limited to 60k rpms, so whatever voltage doesnt put you over that is ( in principle ) fine- not exactly a daily driver kind of setup though, wouldnt really be ideal for offroading at ~70mph for example ( whicj is why speed runs are done onroad, not off ). I figure a lighter weight CF flux would be fine offroad with the MMM system & sensible speeds, then turn the original heavy weight version into the road missle with a single massive motor ( or dual motors if you really wanted to ) & HV esc. The heavier weight would be better for getting good traction & keeping the front end down- most guys have issues with lighter weight speed machines as the wind lifts the front end at higher speeds, so have to resort to front wings and such. Heavier weight would place a bit more load on the electronics, but if the motor/esc/lipos are upto task, then it shouldnt be an issue really ( just takes a little longer to reach max velocity ).
swiftneed 05.03.2010 07:47 PM
Are they going to run in sync with eachother and what about voltagewise what lipos
suicideneil 05.03.2010 07:51 PM
The syncing thing is easy enough, just short two motor wires with a single sub-c cell to align the rotor to a certain posistion, repeat for the other motor ( same wires ), then mount the motors & pinions + mesh to the spur without rotating the shafts before they are meshed. Once meshed, they will stay synced until one motor is un meshed and the shaft rotated freely of the other motor.
Jahay 05.04.2010 04:00 AM
neil thanks for the help... I didnt know the motor was capable of 60000rpm...
If that is the case, my current gearing which is:
Differential Ratio: 3.2222222222222223
Transmission Ratio: 1.5366847826086956
Other Ratio: 1
Spur Tooth Count: 47
Pinion Tooth Count: 17
Total Voltage: 25.2 - rated at 4.2V per cell when fully charged.
Motor KV: 1600
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0.5
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.76 : 1
Total Ratio: 13.68955 : 1
Tire Circumference (inches): 20.42 inches (518.68 mm)
Rollout: 1.49:1
Total Motor Speed: 40320 RPM NO WHERE NEAR 60,000rpm!!!
Vehicle Speed: 56.95 mph (91.49 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
This is on 6s rated at 4.2v not 3.7v... and what i would be running most of the time.... only 40000rpm!!!!!
You say that this motor is rated to 600000 so theoretically with a better speed controller i could run 8s for road use as not to cause the motor or esc any harm... Is this really possible???
This is the same gearing but on 8s
Other Ratio: 1
Total Voltage: 33.6 - 8s rated at 4.2V per cell
Motor KV: 1600
Rollout: 1.49:1
Total Motor Speed: 53760 RPM - still well below the 60,000 rpm mark!
Vehicle Speed: 75.94 mph (121.99 km/h) - I WOULD BE HAPPY WITH THIS FOR ROAD USE!
If this is correct... i doubt i would need to start building a twin motor savage or increasing motor size!!! This would make me happy as i would rarely run 8s, but knowing i can makes me happy lol just need an appropriate HV ESC.
please confirm this neil before i get too excited
nuz69 05.04.2010 04:08 AM
You don't need to go to the motor limit, keep in mind that the efficiency of the motor will be poor at 60 000 RPMs, so 8S will be plenty and will give you a safety gap between your RPM and motor RPM limit.
All you need now is if you have already a 1520 two 4S batteries and a HV ESC :D
Jahay 05.04.2010 04:49 AM
OH YES YES YES! Nuz... Just the response i wanted to hear!
i was under the impression that this motor was only good for 6s!!! (dont know why)
Of course i dont want to hit the motors limit... But considering when i was using my 1515 2200kv motor on 6s... it was at 57000rpm and was doing fine... This motor on 8s is more efficient than the 2200 on 6s as its only spinning 53000rpm!
Now my next question is regarding choosing and appropriate HV ESC...
Now considering the MMM is rated at 120amps continous... I would need something that matches that or higher to run safely correct???
Does that mean that the HV-110 is not adequate and i would be forced to go for the HV-140???
What are the main difference between these two ESC???
Phoenix HV-140 = $359.00
Phoenix ICE HV-160 = $320
Same max voltage yet the cheaper ICE is rated to handle more amps.
Whats the main difference... And what do people recommend?
THANKS!
