-   -   How to bind a spektrum reciever? (https://www.rc-monster.com/forum/showthread.php?t=26843)
superek4 05.06.2010 07:05 AM
i am using a KO EX10 tx n spektrum module. I am using SR3300T rx. How do i bind it?
i check with spektrum website which is below.
http://www.spektrumrc.com/ProdInfo/F...structions.pdf
but it doesnt seems to work.
From what i understand is i will switch on the rx first with the bind plug then turn on my tx pressing the bind button then it will bind.
do i need to off the rx n remove the bind plug n turn on again?
or i remove the bind plug wo switching off?
superek4 05.07.2010 12:07 AM
No one?
suicideneil 05.07.2010 10:43 AM
When I setup my dx6i, I plugged in the bind plug, connected up an rx pack ( no esc connected or anything ), then held the bind switch on the tx and turned the tx on. It took two attempts, but on the 2nd go I got the rx bound to the tx and its been fine since. You might just need to try an rx pack to power the rx, rather than using an esc to supply power. Once its bound you can remove the bind plug.
superek4 05.07.2010 05:47 PM
Thx I did wat u told me n it bind but the telementry system is not working with my telementry spm 1305( combo telementry system)
do I need to bind that too?
The temp sensor was reading 999degree.
suicideneil 05.08.2010 03:00 PM
I dont have telemetry on my radio, I have no idea how you set that up Im affraid.
