the better battery set-up??
Hello, just wondering what would be better running 1 6s 5000 lipo battery, or two 3s 3000 lipo batteries. Pros and cons
Mike ps. running neu 1521 with an RX8 |
1. 6s 5000 is a nice setup and will power the 1521 just fine as long as they are 25C or better packs.
2. two 3s 3000, I'm assuming they will be wired in a series? If so, they would need to be higher C rated to provide the amperage needed for the 1521 to run efficiently. What C ratings are these packs? |
They would be hyperion G3's so 35/45
(1)6s = high wattage needed, faster charging, big power supply, big charger, possible configs...6s only
(2)3s = lower wattage, slower charging, smaller power supply, smaller charger needed, possible configs.......3s 3000mah/3s 6000mah and 6s 3000 C rating is C rating no matter what the configuration.? Do you run any 1/10 scale? |
With the Neu 1521 assuming its a 1Y or 1.5D, the Hyperion 5000, 6s, 35C pack will really shine and power this setup like it should. The 3000's would need to be configure in 6s would be less than required. |
Only differance is going to be your run time due to the different mah ratings. Your power level will be identical (assuming same C rating on both scenarios).
Assuming both have reasonable C-rates, I personally would go for the 6s 5Ah option. 6s @ 5Ah is 111 watt-hours, and 6s @ 3Ah (or 3s at 6Ah) is 66.6 watt-hours. Clearly the 6s 5Ah option is better.
The only advantages to the smaller packs is reduced weight and flexibility to run 6s @ 3Ah or 3s @ 6Ah. |
Thanks for the correction. Now I gotta go make sure I've planned out my batteries correctly:oh:
Jeff- post your setup/plans so we can help assure you are set up correctly.
I was just referring to my plan for the Flux. Since i extended it, I had been thinking about going to a single pack so that I only have one style of battery to worry about on all my trucks. I had shelved that idea after looking at the fairly low price on those new Hyperion and Neu 3S batteries. But they would have been a lower mAh rating than I have in my 5S and 6S packs (I think a 4K pack is about as thick as I can run in the Flux cases). Now, I will just order another 5S pack with the higher discharge, and try to mod up a single pack case between the rails.
Now that I think about it - I haven't ever run the Flux since I did all that work on it last fall......gotta get out and play! |
| All times are GMT -4. The time now is 03:26 AM. |
