Looking for a Medusa 36-50 motor
Im looking for a Medusa 36-50 4800kv(prefered) or 3300 kv, 5mm(prefered) or 3mm shaft motor. I plan on using it in my Hyper Mini Ste.
Mike has some 36-60 3100 kv in the RCM store. With the extra torque it would be equivalent to the 4800kv 36-50 most likely.
Judging by the preferred kv, he's probably going to run 2s. The 3100 will probably be a little slow unless he gears up to compensate. On the other hand, that 3100kv motor would be really sweet on 3s.
Well I am always for lower kv higher voltage! :yipi:
| All times are GMT -4. The time now is 09:20 AM. |
