-   -   D8T battery tray (https://www.rc-monster.com/forum/showthread.php?t=27058)
sabongi 05.24.2010 03:22 PM
D8T battery tray
Would the d8t tray fit the traxxas 5626 esc holder?
Description says nothing, but i presume yes since the separate tray is the same as the tray that comes with the kit, right?
RC-Monster Mike 05.24.2010 10:42 PM
Correct. The D8, Losi 8, Losi ten T, Inferno GT2, and Mugen MBX6 and MBX6T trays all accomodate the RX8 directly and the MMM with the Traxxas holder. :)
sabongi 05.30.2010 05:09 PM
if i cut the motor shaft will i have enough clearance to use the stock radio tray with your motor mount, cutting between the brake servo and front box?
bdebde 05.30.2010 06:09 PM
Probably not, I used a motor plate that attaches to the rear of the diff mount, which puts it farther back than an integrated diff/motor mount, and I barely have room for pinion with stock radio (receiver battery) box.
RC-Monster Mike 05.31.2010 10:27 AM
It is possible to use the stock tray(most anything is possible), but much less ideal.
