-   -   My HPI MT2 reborn (as electric of course) (https://www.rc-monster.com/forum/showthread.php?t=27109)
IGT_7x 05.28.2010 08:35 PM
4 Attachment(s)
Here she is, my reborn HPI MT2 now sporting a brushless setup & an extended chassis. As you can see it's almost as long as my Slash. Now let's see how she performs :yipi:
IGT_7x 05.28.2010 08:36 PM
3 Attachment(s)
More pics :yipi:
suicideneil 05.28.2010 10:16 PM
Thats pretty sweet, Im guessing custom or aftermarket chassis + stretched too. Mean looking slash aswell :yes:
IGT_7x 05.28.2010 10:33 PM
Thanks, yes it is custom, actually it's from CKRCcrawlers.com, they have it as a kit. I just went ahead & used a Sidewinder ESC & Velineon motor, it should be enough since I'll be using 2-3s lipo. As far as the Slash it's been one hell of a truck, tough as nails.:diablo:
reno911 05.28.2010 10:46 PM
Hey CKRC stuff. Glad yours turned out, and you got everything in the shipment. I worked there for a week. Literally, Jake is a bit of a skiddish dude. It has to be tough, because of the way Jake races... He makes some good stuff, and it is the best LHS in my area. However, do to a sticky situation I hold back my urges to shop local.
swiftneed 05.28.2010 11:27 PM
Hey I have two of those Hpi Mt2 I will be digging them up and trying a conversion and what were the necessary parts and anything custom?OK found it said sold out but requires quite a bit of work not like RCM drop in and go
swiftneed 05.28.2010 11:31 PM
I didnt see anything that said conversion can you let me know under what
Bondonutz 05.29.2010 12:31 AM
Both look pretty sweet, nice work !
reno911 05.29.2010 12:49 AM
Call them. It is no longer on the website but I am pretty sure they still have the custom lower and top plate for the chassis. As for everything else. I could probably get you the parts that are need if I asked what they were.
If they say no PM me I can check when I go in next time.
reno911 05.29.2010 12:50 AM
Nevermind it is still there.
http://www.ckrccrawlers.com/ckrcmt2s...on-p-2450.html
IGT_7x 05.29.2010 02:44 AM
The kit will include everything you would need for the conversion, but it does require a little bit more work (a dremel helped a lot) but once you're done it'll be sweet:yes: Once you get the kit the instructions can be found here: http://www.ckrccrawlers.com/infockrc...on-p-2453.html
swiftneed 05.29.2010 11:40 AM
Thanks
ta_man 06.01.2010 07:48 PM
Did you do that klugy thing with the Traxxas sliders for the front or find a better way?
IGT_7x 06.01.2010 08:03 PM
Yes I did till I find a long enough dogbone to replace it, but I've tested it & so far it's holding up.
