Where to buy a Medusa ROTOR?
My both Medusa 28-56 motors failed because the endcaps pop off thus the carbon fiber wrapping was partially gone. I drilled three holes/added 3 screws to hold the endcap in place, it worked for some seconds and then the rotor splits into pieces.... looks like the wrapping IS necessary. :whistle:
So my question is where can I find Medusa replacement rotors? Will Neu sell MR series motor parts? Thanks guys. |
Wrote an email to Neu but nothing ??
I'd like to know this as well since I messed up my Medusa's rotor.
I have a 36-70-2000kv motor that needs bearings.
If you guys spot a place that sells those, let me know please. Thanks, James |
What was the name of that online bearing retailer someone mentioned recently- they have loads of oddball sizes available that should be suitable.
I'd keep trying to contact Neu, or maybe Castle can get a message through ( being their distributor & all ) for you regards a new rotor. |
end bell failures on medusa's
Hay suicideniel, Iv'e had the same problum on my medusa 36-60-3100.It pushed the end bell off and destroyed the can bearing.as well as rubbing the coating off the rotor.on my motor atleast the bearings are 5x10x4 /1/8 clutch bearings and they pushed out fairly easily and tapped in even easier.I was worried about the coating but on my rotor but i think its just epoxy so i replaced both bearings and got one of Mikes motor mount heat cync/clamps put it all back togther and its been running for three weeks maybe 300 laps and all under 115 deg , for what ever thats worth. good luck and happy 4th!
I have a buggered rotor too, I haven't contacted neu yet but I was planning on sending it to them so they can do the rotor and bearings for me. I'm sure it's not hard but I reckon I for the price and trouble of finding the parts and doing it myself I can just send it to them and have confidance in a good job.
I send a failed medusa (36/60/2200) to neu. They didn't have medusa parts 3 months ago and they offer to sell a neu motor %50 off instead of reparing my medusa. I'm waiting them to build.
i think medusa now is use & dispose. Cant repair anymore |
I've also got a medusa 36/70/2000kv that needs a new rotor,if any one has one they want to get rid of let me know.
| All times are GMT -4. The time now is 02:24 PM. |
