FS: Losi MRC Tuber
I've got an MRC with a Metal Fume Fab "Skunk" tube chassis
It's also got brand new MIP shafts and a Futaba S9551 Low-Pro Digital servo. Also has: Stainless steering links RC Bros: lockers fr&r, servo mount, battery mount, Delrin high clearance links Losi: alloy shocks(Droop), center locker, front cvd's, Mini Blue Rock Claws w/Mem foams, alloy wheel hex's Holmes Mini Torque Master motor w/extra brushes Tekin B1r ESC Mahem Eng. 7 Wheels Blk w/Silv Star rings outside-standard ring inside(gives 2 different looks if you switch em) TCS: 3 link plates, axle support plate,Upgrade hardware kit, Internal shock springs Soft & Med 3x Rhino 610 2s LiPo 1x Rhino 410 3s stock motor,esc,chasis & body never used Stock wheels have weights and the rings are there to make them functional beadlocks.(I find these work better on the couch than the Blue Claws) The 3 blu foams are what came with the blue Claws, if I find the 3rd it will be included 1 axle is starting to click when really loaded, included is a Diff shim kit which should fix it right up. Have spare axle housings, complete screw kit, plus all stock take off parts minus the Trans & Rec The Futaba receiver in pics is not included All in all this truck has less than 10hrs use on it, but it was fun to build. If you have any questions don't be afraid to ask, I'll try my best to answer any Q's fast. PM for pricing http://i244.photobucket.com/albums/g...n/100_2732.jpg http://i244.photobucket.com/albums/g...n/100_2727.jpg http://i244.photobucket.com/albums/g...n/100_2728.jpg http://i244.photobucket.com/albums/g...n/100_2729.jpg http://i244.photobucket.com/albums/g...n/100_2730.jpg http://i244.photobucket.com/albums/g...n/100_2733.jpg http://i244.photobucket.com/albums/g...n/100_2741.jpg http://i244.photobucket.com/albums/g...n/100_2739.jpg http://i244.photobucket.com/albums/g...n/100_2737.jpg http://i244.photobucket.com/albums/g...n/100_2738.jpg |
| All times are GMT -4. The time now is 11:35 AM. |
