1000Watt 10S Charger!
I just saw this charger at HC, I'm very impressed about the power: 1000 Watt! :surprised: And that for only $180, very cheap imo...
Specs: Input voltage range: 4.50 – 38.0VDC Charge current range: 0.05 – 30.0A Discharge current range: 0.05 – 30.0A Maximum charge power capacity: 1000W @ input voltage 23V (500W @ input voltage 12V) Maximum discharge power capacity: 80W Maximum regenerative discharge power capacity:1000W Maximum extern discharge power capacity: 1200W @ 40V/30A Current drain for balancing: <500mA Balance accuracy: <10mV Lithium (LiPo/LiIo/LiFe)battery cell count: 1 – 10 series(In non-balance mode, expand LiFe to 12s) NiCd/NiMH battery cell count: 1 – 25 series Pb battery cell count: 1 – 18 series (2 – 36V) Log Files storage: 16Mbit (31 hours) Battery setup memories: 10 Intelligent temperature control: Yes PC Connect: USB port Weight: 750g Dimensions (L X W X D): 143X123X46mm / 5.63X4.84X1.81in Link: Click! But... which power supply should be used for this thing? :intello: (HC only got 400W Power Supply's iirc...) |
I wanna know who uses a 10S, and in what..
sounds good! I just don't like the 23V power supply requirement. |
I got that e-mail this morning. Pretty cool. My 200 watt 10amp does fine for everything I do so far. I can't see myself needing that until the ESC manufacturers catch up and make something that we can use this with, along with the battery packs themselves.
Since I have been very impressed with my iCharger 106B+ I think this will be my next charger, once more reviews come back, and maybe in a year or so the price will come down (although $180 is a great deal, you still have to factor in a 24V 50A power supply if you want to get the rated 1000W, and that will add to the cost)
People always say "But what do you even need that for? you'll never need that" I'd rather have it and not need it, than need it and not have it. Battery technology is screaming forward with no sign of slowing down. Get a charger that will be able to keep up. |
I'm just gonna wait until batteries can be charged at 200C, and then just plug them straight into a DC source for a few seconds. :smile:
no stop bashing!!! :intello: |
I post awhile ago about this charger in the general electric forum.I also have a link in that post goes directly to the manufacture.
P.s. Greathobbies in Canada is going to sell this 2 |
Great for parallel charging, I have one on order.
Great hobbies is going to sell these but for $249.00 Wow that's some mark-up. |
And with a 30A charge-rate, I can finally charge my Turnigy 40C 4S 5000mAh LiPos at the 5C (25A) they say they can safely be charged at! Plus, ProTek (the makers of the iCharger series of chargers) is an awesome company, they make awesome products, and they have awesome service! |
Also, when you are looking at the item, if you look at it long enough, this little discount window pops up...if you click the add to cart button on the discount window, you get the item for the much cheaper discounted price...this works on every product HobbyCity/HobbyKing carries.
http://pics.offroadextremes.com/rc/3010B.jpg |
| All times are GMT -4. The time now is 03:49 AM. |
