Best Revo Bashing setup?
I just picked up my new MBX6, and now that I have that and my truggy, I will not be racing the Revo 3.3 Vantage Carbon Fiber Brushless conversion anymore. So I am going all bashing. I'm looking for a good bashing suspension setup. I already have all of the needed durability upgrades and what not. I'll be dong some decent sized jumps, BMX track, maybe some skatepark. What do you think is a good bases setup?
Springs: F- R- Shock Oil: Swaybars or not? Which rockers? What suspension pushrod location? Thanks |
I run 50wt front and rear on a set of integy tuning springs,I can't remember what stiffness but, they were the stiffest in the pack
I also run sway bars,silver front and rear P2 rockers with the pushrods set half way in. I like the stance it gives and P2's with pushrods on the inner hole make for a stiff setup for jumping.--Josh |
here is the setup I just switched too
f/r 70w oil Springs orange front Springs Gold rear Techno sway bars Pushrods in center using p2 rockers F/R diffs 30k diff fluid in my Cd in the tranny 100k diff fluid upper suspension pins in upper holes on both front and rear |
| All times are GMT -4. The time now is 02:49 PM. |
