How do I calibrate a Venom Pro Charger? HELP!!
The cell voltages on the charger all say 4.20 but my multimeter says they are off my up to 0.03v. Is it possible to calibrate the balance port? I know the main port can be calibrated.
Thanks |
It really doesn't help to post the same question in seperate forums, in fact, it is frowned upon.
And to add insult to injury it shows you are offline, so you're not even here to receive the answer to your question that was so important that you had to post it twice. Oh, well, not that big of a deal. .03v difference isn't enough to worry about, just run with it.:yes: |
Also, how do you know the multi meter is the accurate device? Cheap meters can sometimes be off by quite a bit, and even if the meter isn't cheap, it needs to be recalibrated at least once every 1-2 years.
no, im online, but I have it on my ipod touch,. and for some reason it shows me that im offline on my ipod, and posting it twice is the only way I could get answers anyway.
the multimeter is from my dad who works at shaw cable, its like a 300 dollar multi-meter.
yes, but its over charging my lipo's, i had some cells at 4.23 |
ok, just downloaded the manual, and no info on my issue. Ill just call venom tomorrow.
4.23 is okay is what we're trying to say, we're not trying to blow you off.
Just use it as is, you'll be okay |
You probably can't calibrate the charger like you are thinking. If anything, see if you can set a different CC/CV threshold; something like 4.15v/cell. That 0.03v extra will actually be 4.18v which is pretty close to 4.2v.
ok, but im still concerned, one charger is putting in 2K mah, and another one 1.5
k mah........ i dont know anymore. |
If one charger is charging one or more cells a little more than the other (your 4.23 reading) That could explaine the difference in mah. Unless the batteries get unreasonably warm during a charge I wouldn't worry about it. It's easy to over analyze this stuff at the price we gotta pay.:intello:
I have ,and use daily the same charger that you use.the minimal voltage variation you are seeing imho will not effect anything.Like i previously stated ..03 volt is not worth worring about.If you were talking .3 volts there may be a problem with your charger and or battery.
ok, so if it reads 4.23, instead if 4.20, i shouldnt be worried?
| All times are GMT -4. The time now is 02:47 AM. |
