Feigao Motor Brace
So Mike, whats the progress of the motor brace? I hope to get one around the same time i get my stuff back to prevent the back plate from poping off (happens a lot during a hard run). Do you have any pictures of it? When do you think the release date will be?
I should get a pair of prototypes today. If they work well, I will have them in stock next week. I will post a picture on the site when they arrive.
AH man. I cant wait!
I noticed the brushless I ordered is heavier than the brushed motor I'm running right now in my Stampede. I did add a washer to the screws that hold the motor but will that be enough to hold the 8s motor or should I get a plate for it?
I would get a plate for it. I can see the plastic getting eatin up over time from the power.
Now once FLM releases the aluminum tranny case that would be the way to go. |
The motor brace/heat sink will not fit in the small motor area of the pede, unfortunately. Fortunately, though, with the motor mounted sideways like it is in the pede, it becomes a lot less likely that you will experience any trouble.
| All times are GMT -4. The time now is 05:39 AM. |
