-   -   Castle Neu 2200kv bad bearing? (https://www.rc-monster.com/forum/showthread.php?t=27383)
Stoomstrijkijze 06.25.2010 12:41 PM
I have a brand new MMM V3 combo with the 2200kv motor for my mbx6. I finished my build yesterday and I've been to the track this afternoon to test it.
I ran 2 lipo's with 13/46 gearing. My motor was around 63°C after each run, so temps were good.
When I came home and did a check up of my buggy I found out that there was play on my motor shaft. I compared it to my other 2200kv motor (that is 4 months old) and that motor is still in perfect shape.
I tried to remove the bearing and go to the hardware store but I can't get the bearings out of the end bells. I guess the rear bearing is still fine. Just the front one has play in it.
Anyone had this problem too?
Arct1k 06.25.2010 01:08 PM
Play in rotor or bearing? The rotor is designed to float a little 1-2mm and settle into its "optimum" poistion.
Stoomstrijkijze 06.25.2010 06:07 PM
It's play in the bearing. You lift the shaft up and down, and right and left. I know it's normal you can push/pull it a bit.
When it's spinning free I makes a loud noise :(
suicideneil 06.25.2010 07:37 PM
Hmm. You can tap it out using a wooden dowel & a hammer- they are glued in as standard.
Arct1k 06.25.2010 07:51 PM
Ring them up or email support my guess is they will send you a rebuild kit
Stoomstrijkijze 07.15.2010 01:33 PM
Could I get an opinion of Castle? I was very busy the last month, but I think I'll send them an email soon.
Pdelcast 07.15.2010 09:14 PM
Shoot me a PM with your shipping info, and I'll send you a replacement front end-bell with bearing.
Thanx!
Patrick
Stoomstrijkijze 07.18.2010 06:08 AM
Thanx!
Patrick
Thanks!
Stoomstrijkijze 08.03.2010 11:32 AM
Wow, I recieved a full repair kit for my Castle motor!
Awesome service Castle Creations! :yipi:
Thank you!
