What needs replacing??
Hi guys,
I bought myself a RCM Slipperential via eBay (turned out it was from Bryan here). Now I got it but there is a big wobble in the output yokes (Bryan mentioned this in his ad). So I was just curious what I should replace: I put together a small movie for you to check the play: [YOUTUBE]Q54veG7vc7g[/YOUTUBE] I'm guessing it are the two end cap plates that are worn out? I've read Mike made some hardend steel versions that should ''last forever''? Thanks guys! EDIT: Any other hints on what would need replacement while rebuilding, some gaskets and o-rings? |
Its most likely the aluminum end caps Nard.They would wear faster than metal cups. sorry about not returning your email.
No problem.
I'm thinking it are the end caps as well, will order me a set together with a nice MBX6Te conversion :D |
hardened steel small and large end bells
Yes the part that holds the outdrives wears out making the outdrives wobbles.
| All times are GMT -4. The time now is 03:28 PM. |
