-   -   Do you guys race with drag brakes? (https://www.rc-monster.com/forum/showthread.php?t=27397)
superek4 06.27.2010 08:19 AM
I have been racing for 1 year plus but just last week I tried drag brakes 10-15%.
Very good driving wo need to brake much as it brakes when I let go throttle.
It ran slightly hotter but was ok.
What %?
E-Revonut 06.27.2010 10:04 AM
I have the drag set at 10 or 20% in my truggy for racing
superek4 06.27.2010 10:28 AM
me too, on my buggy n truggy. so do u still brake? does it affect jumps?
E-Revonut 06.27.2010 11:01 AM
I still have to brake..A LOT!!! Track I run at has a lot of high speed parts that you have to slow down real fast after to get around a tight corner at the end of. The only reason I use the drag brake is that it seems to help with jumps, it's just enough brake to get the truck set to land perfect as long as I don't hit the jump all messed up, so I usually don't have to do to much correcting in the air
Semi Pro 06.27.2010 12:30 PM
I'm not running any drag brake in my buggy, it took some time to get used to but i like it
shaunjohnson 06.27.2010 05:45 PM
i dont run drag brake, but i have set them up so that the wheels will not completely lock up on hard brakes. this way i can keep steering.
superek4 06.27.2010 07:04 PM
How u do it?
Semi Pro 06.27.2010 07:30 PM
Originally Posted by superek4 (Post 371496)
How u do it?
start at about 50%, take it out and test it, then if it locks turn it down another 5% and do it again untill you find the sweet spot. every buggy,tire and track will be diffrent.
i perfer to just learn to control my brakeing
What's_nitro? 06.27.2010 07:32 PM
A lot of radios have an ABS feature as well that will pulse the brake channel to avoid lockups.
tedo 06.27.2010 10:45 PM
I use 0 drag brake, and 40% brake strength on my RX8. Seems like the perfect set-up for the track. Buttery smooth braking, yet you can still free-wheel into the corners.
rootar 06.28.2010 12:42 PM
no drag on my 8th scales. now on my 2wds i run a little drag brake to make it feel a little more planted off power (like the old brushed motors)
