-   -   hacker C50 maxx with a snaped shaft... (https://www.rc-monster.com/forum/showthread.php?t=27439)
whitrzac 07.01.2010 01:16 PM
I snaped the 3mm shaft on my C50, has anyone had any luck replacing the rotor with one from a different motor??
nitrostarter 07.01.2010 01:24 PM
There is a 5mm shaft upgrade for that motor IIRC....
snellemin 07.01.2010 03:09 PM
New 5mm rotor is 75 bucks from aero-model.
whitrzac 07.01.2010 11:50 PM
I paid $50 for the motor, I would rather find something else thats cheap...
lincpimp 07.02.2010 12:22 AM
L can rotor from a feigao?
whitrzac 07.02.2010 01:18 AM
I can give it a try, but I need to order one...:neutral:
does anyone(linc...) that they want to get rid of for cheap:whistle:
steveo 07.02.2010 05:19 PM
the rotor from an L size motor will work i have used before, i had the same issue with my shaft, but for only $10 price difference for the L motor to use its shaft the quality is not the same
whitrzac 07.02.2010 05:55 PM
I was planing on getting an ebay/HK motor feigaos are tooo much:lol:
ZippyBasher 07.02.2010 06:53 PM
http://www.castlecreations.com/produ...pair_kits.html
1512 size? rotor Diameter may be a problem. But only $25:smile:
whitrzac 07.02.2010 07:14 PM
the rotor from a tekin buggy motor fits, but the 4pole VS 2...
aka it cogs like a ******
Bondonutz 07.02.2010 07:38 PM
Another avenue if on a budget ?
http://shop.turbofanelectrics.com/ca...?categoryId=11
steveo 07.02.2010 11:31 PM
but its the stator that is 4pole, does the rotor have to match, are they 2,4,6, pole rotors?
i dont know if there is an easy fix i would like to get a good quality rotor for my c-50 if this works
sikeston34m 07.03.2010 12:17 AM
Yes, they have to match.
2 pole is N-S
4 pole is N-S-N-S
6 pole is N-S-N-S-N-S
This is the Magnetic Configuration of the Stator AND the Rotor.
Mismatching these doesn't work.
steveo 07.03.2010 01:15 PM
2 pole is N-S
4 pole is N-S-N-S
thanks that is good info
