What size gearing would you recommend.
Hi, I am planing to go with a Tekin 1700kv motor/combo on 5s in a Truggy.
The Spur gear is a 50T. The clutch bell that it was running with nitro was a 13T. The question is what would size would you recommend for a pinion gear for this motor battery setup for racing. Should i stay with a 13T or go up a few sizes or down? Any information is greatly appreciated. Cheers. |
Based on a tyre diameter of 5.65" ( average-ish 1/8 size, bowties in this case ) and normal truggy diff ratio of 43/10, then 50/13 = 32mph. I'd say step it up a bit really and go with 44/13 ( = 36mph ) maybe, depends how large or tight your track is.
http://www.scriptasylum.com/rc_speed/_top_speed.html Quote:
Thanks for the reply.
So doing a few more calculations 50T spur and 15T pinion = roughly 36.5 mph. Excellent. 15T depending on how tight the track is. Appreciated. Cheers. |
| All times are GMT -4. The time now is 05:36 PM. |
